Is this alignment setting good for just daily driving?
Old May 12, 2006 | 06:35 AM
nbpal4000's Avatar
i just got an alignment done on my car.
LF:
Camber -0.3
Toe -0.03
RF
Camber -0.6
Toe 0.01
LR
Camber -1.3
toe 0.17
RR
Camber -1.2
toe 0.18
is this good for just daily driving ??
thanks
Old May 12, 2006 | 06:47 AM
PVD04's Avatar
I would go with more front camber, less rear camber, and zero toe on all 4 corners. With that setup you are going to wear the inside edge of your rear tires during normal driving and if you take any corners agressively you will wear the outside edge of your front tires.
-Paul
Old May 12, 2006 | 08:03 AM
AfireINSIDE's Avatar
I have the same question and am unsure of my alingment... this is from my print out. it is in degrees
Caster
Left 3.66 deg
Right 4.02 deg
Front
Left -0.61 deg camber
Left 0.01 deg toe
Right-0.38 deg Camber
Right 0.00 deg toe
Rear
Left -0.39 deg camber
Left 0.14 deg toe
Right -0.18 deg camber
Right 0.12 deg toe
Thrust angle 0.01 deg
Old May 12, 2006 | 10:59 AM
Dumb Evo Guy's Avatar
Caster
Left 3.66 deg
Right 4.02 deg
Front
Left 0.01 deg toe
Right 0.00 deg toe
Rear
Left 0.14 deg toe
Right 0.12 deg toe
Caster is OK, should be more on right than left for road crown.
Front camber should be -1.0* and the toe should be in -0.01" each side
Rear camber should be -.5* or -1.0* max and toe should be in -0.01" each side
I usually set the rally car up with -1.5~-2.0* camber in the front and toed in 2 mm total, and -1.5* camber rear and toed in 2mm... this gives the car a stable nuetral feeling and helps turn in... just my basic set up opinion...
Old May 12, 2006 | 12:27 PM
how will my settings affect me? thanks
Old May 13, 2006 | 09:06 AM
The basic camber settings will be ok, the rear toe has me concerned... I prefer on street cars to have the toe in as minimal as possible, regardless of what the machine says... you can cause the rear tires to wear the outer edges with too much toe in...
Old May 20, 2006 | 05:27 AM
MaxR's Avatar
the evo service manual suggests
front camber either
-1.0 or -2.0
toe in should be 0 +/- .08 in
rear camber -1.0
rear toe in 0.12 +/- .07 in
Old May 26, 2006 | 06:55 PM
spiderm's Avatar
front camber either
-1.0 or -2.0
rear camber -1.0
Is that rear toe-in specs per side or total?
Thanks.
