aerodynamics discussion in chassis engineering
Old Jul 19, 2006 | 08:41 AM
  #46
Ludikraut's Avatar
Do you guys have any info on fender louvers? You see them on most, if not all enclosed wheel racecars, but what is the benefit of going with a top mount louver (seen on some ALMS cars) versus one on the side (DTM)?
I also found this: "Race Car Aerodynamics: Designing for Speed (Engineering and Performance)" by Joseph Katz
l8r)
Old Jul 20, 2006 | 12:24 AM
  #47
JasonS's Avatar
l8r)
Excellent book, I've got it in my living room. I've read it about 50 times and looked at it probably 50 more.
Old Jul 26, 2006 | 04:33 PM
  #48
EVOlutionary's Avatar
http://www.mulsannescorner.com/chaparral2j.html
This is the original sucker car. Snomobile engine powering two big fans in back that sucked the air out from under the car.
EVOlutionary
Old Jul 26, 2006 | 04:38 PM
  #49
trinydex's Avatar
that is damn cool
Old Jul 26, 2006 | 06:59 PM
  #50
I believe some of the A-Mod cars in autocross use this same strategy, except on a smaller scale. I think they use a leaf-blower motor on those.
EVOlutionary
Old Jul 26, 2006 | 11:39 PM
  #51
trinydex's Avatar
wonder when they'll ban that...
Old Jul 27, 2006 | 11:38 AM
  #52
Don't know. Probably won't ban it. A-Mod is pretty much all-out do whatever you want to go faster. They are open-wheel formula cars with giant multi-later wings front and rear. Some have side skirts that scrape the ground to keep all air out from under the car.
Old Aug 7, 2006 | 07:13 AM
  #53
GTWORX.com's Avatar
l8r)
I have that book. Very cool.
- Andrew
Old Aug 23, 2006 | 01:15 AM
  #54
trinydex's Avatar
Originally Posted by x838nwy
Thanks for the info, Mr.trinydex.
Yeah, how stalling reduces drag I don't really know. At least it is possible to stall when you're going too fast which is what they said they're try to do. I could well be that it's just a journalist getting a little confused but I've seen it mentioned in more than one place. Unfortunately, neither of these locations mention it in any detail.
I'm chatting to a prof. on aero eng. this evening and will prolly ask him about it. Wouldn't guarantee he'd know but I guess that's why Adrian Newey and co. gets paid 3million pounds a year for doing what they do...
to bring this back up i was watching grand prix at indy and they note that the wings now have a stiff arch that keeps them seperated. somehow before the wings were flexible and at high speeds they would deform in some advantageous way. the details i'm just not sure of still.
Old Aug 23, 2006 | 03:34 AM
  #55
x838nwy's Avatar
^That's the device the FIA have told all the teams to fit in an effort to keep the separation constant. The somehow failed to say that the top/bottom of the arches cannot be pivot joint and that the aero surfaces cannot twist under load.
Basically a number of teams, Renault I believe is one, never really had their top element deflect vertically to meet the bottom as much as have it twist to meet the bottom...
I spoke to a prof. at an aero department and he rekons the wing deformation is nothing new. Basically if you have two elements that at some point come together to form one then you effectively have two wings. If you're clever enough then you might be able to make some use out of it. He doesn't quite know either and is quite worried about the response in the in-between stages.
As far as I am concerned, (mech. eng - hated aero at uni) wouldn't that mean you need oodles of computing time to work out what happens at the various stage of the deflection and to design in something that deflects form one shape to another really predictably - while using a non-isotropic material? Now that's a job I don't want.
Old Aug 23, 2006 | 03:45 AM
  #56
trinydex's Avatar
or you could just send it out with a driver and hide the results. which is what likely happened.
Old Aug 23, 2006 | 03:52 AM
  #57
x838nwy's Avatar
yeah, I think when McLaren tried it with the whole rear wing assembly tilting back at high speed, Kimi wasn't too pleased when his came off at around 200mph!
anyway, I'm can't wait to hear the verdict on the latest charade with the FIA claiming that a 'mass damper' {a bit of steel/tungsten on a spring inside the car} is actually an aerodynamic device....
Old Aug 23, 2006 | 10:46 AM
  #58
RyanM's Avatar
Active Aero honda project that could be done with an Evo as well
http://www.diynetwork.com/diy/ab_par...918834,00.html
Old Aug 23, 2006 | 02:33 PM
  #59
oneguy's Avatar
it may be non-isotropic but it can still be modeled using a computational fluid dynamics. NASA tested and aero elastic wing on an F/A-18 that was made to deflect under from moments generated bythe aileron. They ended up showing they could close to the same roll rates out of the aero elastic wing as they could with the conventional wing.
Old Aug 23, 2006 | 05:43 PM
  #60
x838nwy's Avatar
Well, it's not impossible, but hey we're talking NASA here! They probably have slightly more powerful computers than most of us. Just a guess.
Anyway, it's one thing to model and quite another to design.
Once they've done all that, they've got to make it then test it as well. I guess that's where all the millions of dollars is going.
