coilover questions JIC
By adjusting my coilovers stiffness to the max stiffness... will it improve the handling or will it make it worse?
please let me know your input and thoughts...
what are the pros and cons from doing this??
it really depends on how low your car is and what your spring rates are and what you are using the car for
if it is a street car, i would only put it to like 3/4 stiffness
because, you may find that with road imperfections, bumps and cracks and bull**** may cause you to skitter or skip across bumps and potholes and **** when cornering and you will lose traction
dont totally slam the car either or you will lose your shock travel
