Brembo rotors
Old May 24, 2006 | 10:56 PM
  #31
trinydex's Avatar
Originally Posted by Z1 Performance
HP has nothing to do with brakes
hp has nothing to do with brakes, but has everything to do with speed... which you include in your statement here:
though...the mass of the car, and the tire do (both in terms of compound and speed).
larger tires acutally make the brakes harder, so the efficciency is really based on which perspective you're looking from. the extra patch of course scrubs off speed in its own right but it also demands more bite and will overpower the rotor pad combo more readily which requires either more braking force or more braking friction with both cause higher temps and a need for more brake cooling and heat sink mass.
Totally agree on the pillar vane "technology". How much testing goes into this vs how much of it is just a "neat" design is subject to discussion I suppose. You'll never see the empiracal data the manufacturers use to determine the type of internal construction, and like I said, there has to be something that they can lay claim to to set them apart from rotor manufacturer B.
to this point i will readily concede that i am a tech engineering junkie when it comes to brakes. i'll ***** myself out for cute fancy lookin' sciency stuff. it's true, we'll never see the darn test sheets. the best we get is repeated flogging and the stand against the test of time.
I've got customer after customer running normal 1 piece rotors (of various aftermarket brands), and most using Ferrodo DS2500 or 3000, on stock calipers with stock sized rotor. I personally do not feel that in a stock size, the 2 piece offers heat benefit vs a one piece. From a weight standpoint, yes they are better. How much it helps you? Very hard, if not impossible, to determine.
i think what i'm mainly trying to say regarding this is that they do work. benefits measureable? shrugs, who's measuring, but work? yeah i think they do. i'm sure they do. obviously i'm not condoning every rotor out there. i know there's shoddy ones that i'll stay away from.
Can the stock rotor design be improved upon? I suppose it can. But if Mitsubishi, a company not exactly flush with cash at this point in history, finds the current design is adequate for the job they intend, they will stick with it.
why would they bother? there's always the aftermarket to pick up the slack.
let us know about hte castrol. that stuff is expensive! O.O i actually never heard of anyone complain about it. question tho... does it hold water and corrode stuff like the motul does?
Old May 24, 2006 | 11:04 PM
  #32
Sharkbite2000's Avatar
Not bad on the price though
Old May 25, 2006 | 03:07 PM
  #33
djbrye's Avatar
Registered User
Lol this thread has become off topic. Can someone help me with any recommendations that I asked for earlier?
Old May 25, 2006 | 03:16 PM
  #34
speedracer2169's Avatar
Well if you have the money buy the brembo sport rotors from tirerack. I have the slotted. Like em. If you're on a budget you can get some rotora's for like 250.
  #35
Z1 Performance's Avatar
triny - that's what happens when I type too fast..I meant in terms of compound and size, not speed. The power of the car has nothing to do with it though. A car that has 1000 hp and that same car that has 20 hp still has the same mass to slow down. I know what you are trying to say though, and to that end, yes the more excess heat you can scrub away from the rotor/pad, the more times you can repeat that same 100-20 mph (for example) stop. That's what makes the BBK's work so well
any brake fluid can retain water - they are all hydroscopic as far as I am aware....I'll have to look into it. I will report back on the SRF, as I am curious how it works too. Sort of like that "I gotta see what a $5 milkshake tastes like"
Old May 25, 2006 | 03:21 PM
  #36
I actually had a customer report he cracked a set of the Rotora on his last track day. However, he had also swapped from the Castrol SRF Fluid to what the Ferrari Challenge cars use (something with a T, I forget the name). Anyway, if you guys need the Brembo rotors, let us know, as we have em in both slotted and drilled
Old May 25, 2006 | 03:26 PM
  #37
Gary_BremboRT's Avatar
It kinda seems that was.
But go back to my first post.
The short answer is...do not buy the rotors you say at the link you posted.
They are not Authentic Brembo Sport Discs.
If you need a referal to an Authorized Dealer PM me or call me. 714.438.1118
Gary - - -
Old May 25, 2006 | 03:32 PM
  #38
I am going to try a set of the DBA 2 piece units. I have never used their product before, but given the cost of the AP rotors, and the fact that I can get the DBA's for less, in a 2 piece, makes them worth my trying. I also will take the opportunity to upgrade to the Castrol fluid and probably try out the HP + or go back to the DS2500, which came with the brakes in the first place. Totally different car I know, but similar weight and similarly sized rotors.
Good discussion guys
I think we'd all like to hear your feedback after you try the DBA 2 pc. discs.
I think the DS2500 pad will be a pretty good match for that disc as well.
You sell Brembo, correct???
Have you tried our Sport EVO 500+ Fluid...or the LCF 600 Plus ???
Old May 25, 2006 | 03:33 PM
  #39
Gary - - -
+1 the real Brembo sport rotors are actually goldish in color. The ones that you posted are just drilled blanks. And FYI OEM rotors gor for like 200 each at the dealer aprox depending on the discount you get
  #40
djbrye's Avatar
Registered User
I know they aren't brembo rotors but thanks for clarifying. I thought they were at first because the logo on the left. My mistake My mistake Anyways, the information specifies it as OEM and dealerships usually charge a lot to replace rotors and they use OEM rotors. I figured this was a good deal for some slotted OEM rotors.
Old May 25, 2006 | 03:36 PM
  #41
I know they aren't brembo rotors. I thought they were because the logo on the left. The information specifies it as OEM.
They can probably be oem rotors but they had a machine shop drill and slot them which comprimises the reliability of the product
Old May 25, 2006 | 03:39 PM
  #42
djbrye's Avatar
Registered User
I will call them to get more info on them.
Old May 25, 2006 | 03:45 PM
  #43
Gary - I'm hoping the DBA's work well for me too; Ken had recommended them to me, and he knows his stuff pretty well
I've yet to try the Brembo fluid though - any specs on it?
Yes we sell Brembo (the real stuff )
Old May 25, 2006 | 03:50 PM
  #44
OK.
You stated that you already warped your last set of rotors.
Were they the OEM smooth/blank Brembo's???
How many miles?
Did you ever experience fade, or did you just end up with vibration??
Old May 25, 2006 | 03:52 PM
  #45
I got 45k miles out of my OEM never resurfaced them. They did develop a nasty lip that made noise like no tomorrow.
