brake upgrade???
brake upgrade???
Ok, I have a set of OEM pads and rotors on my car now and the squeal really bad, so I'm thinking of an upgrade. I've been looking to upgrade my braking system (slotted rotors, pads, and stainless steel lines) for a while now. I was just wondering if anyone had any suggestions to what brand(s) are good and the one(s) to stay away from. I was looking at maybe a set of Hawk HP Plus pads (front and rear) as well as Rotora slotted rotors (front and rear). I was just wondering if anyone has these on their evo now and if they would recommend them or not? Also, if anyone has these, I was wondering if they squeal, or how much brake dust they make. The brake dust is not really too much of an issue, but I DON'T want brakes that squeal.
Any help would greatly be appreciated. thanks in advance.
I'd get a set of drilled rotors instead. I dunno, i've never really liek slotted rotors before. Plus, the drilled ones dispense heat much more efficiently, and don't create much brake dust, but that really isnt an issue for you. I'd just get a set of brembo drilled rotors. just my 2 cents
if you want street, then fo drilled rotors. Track, get slotted. You can;' go wrong with rotora and the hawks. i peronally have endless and stoptech. Go to stoptech.com and see the FAQ section. very informative about brakes and rotors in general.
My evo has almost 36k miles on it, and I'm not really sure when the brakes were last changed, being that I bought the car used about 3.5 months ago. but I really want brakes that don't squeal and stop well. One of my friends has slotted on his 05 and doesn't have any complains. but thanks for your help.
Where did you buy your evo and what color is it? I traded mine in to Garcia Mitsu in Nov.
Anyway, I'd recommend staying away from drilled rotors, too many issues with cracking around the holes. Much better sticking with slotted for the Sandia crest road.
d
EDIT: you did check the pads right?
