Work Wheels Question...
Old Jun 17, 2006 | 05:49 PM
Inprogress's Avatar
Unhappy Work Wheels Question...
I've already asked and been told that my 18x8.5 5/114.3 +43 offset wheels will not fit the Evo IX. I was wondering if there were any way to go about them with possible spacers?
I've been told spacers aren't really that safe, is this true?
Where can I get the best possible spacers to make this setup work? And I assume I only need them in the front?
Thanks.
Old Jun 17, 2006 | 07:37 PM
Inprogress's Avatar
nobody have any suggestions??
Old Jun 18, 2006 | 09:35 AM
Z1 Performance's Avatar
with a big enough spacer and longer studs, they should work fine. You are likely to need a set in the 10-13mm range
Old Jun 18, 2006 | 10:12 AM
Inprogress's Avatar
Do you think 10mm would be enough? Making it a 33mm offset...Do you know where I can get odd number spacers such as 12mm? I figure 15mm would be to big...
Old Jun 18, 2006 | 05:03 PM
Speed Element's Avatar
H&R sells 10mm spacers w/ longer studs if i recall correctly..
Old Jun 18, 2006 | 06:07 PM
Inprogress's Avatar
Cal,
Do you have a link to anyone that sells the H&R's?
I've found these so far, do they seem pricey? I ask only because I dont know how much I should be spending.
http://www.evasivemotorsports.com/me...de=KICS-5110W1
Old Jun 18, 2006 | 08:33 PM
I cannot say for sure what size you'll need..it is going to largely be trial and error
