Gramlight 57F 18X8.5 in a 45mm offset?
Old Jun 28, 2006 | 07:52 PM
shivaswrath's Avatar
I have searched and searched, and can't seem to find any information on this.
Will these rims fit, I'd be running 235/40-18's, maybe 245 at the most.
I don't want to deal with spacers or tire rubbing.
Does anyone have an idea if +45mm will be putting the wheel farther out so that I'll get OUTTER rim rubbing, or will it move the wheel farther in so that I'll be rubbing the struts?
I thought that the ideal offset would be around +35mm so I NEED HELP!
If I could get a response ASAP that would be great, this is a local deal and the seller wants to unload ASAP.
shivas
Old Jun 29, 2006 | 09:43 AM
Neal@tirerack's Avatar
Dosen't seem right. We sell that wheel with a 30mm offset for the EVO. 45mm would bring it too close to the caliper. Thats almost a half inch difference in offset, huge amount when your talking wheels.
Old Jun 29, 2006 | 10:05 AM
TheGVR4kid's Avatar
My 18x8.5 +40 LE37's had MAYBE 1mm of clearance from the caliper in the front, I think you're definately going to hit.
Old Jun 29, 2006 | 04:48 PM
thanks guys, won't buy them then. . .
Old Jun 30, 2006 | 06:45 AM
PPI's Avatar
PPI
don't they have a smaller offset? My 17's are 30 if i recall correctly and fit great.
Old Jul 6, 2006 | 09:05 AM
hokiruu's Avatar
Just to clarify: higher offset will set the wheel further inboard (narrower stance) and lower offset will push them out further. That offset would be more suitable for a Subaru. Personally, I like to run the lowest offset I can while still being able to fit a suitable tire. Wider track, usually more caliper clearance, better wheel/fender flush looks, better looking wheel faces, are all benefits of lower offset wheels. Unless they were ridiculously cheap wheels, getting these and running the necessary ~15mm spacer plus longer studs is just not worth it IMO.
cescpistol
Apr 4, 2014 03:30 PM
pd9000
13
Aug 14, 2012 04:36 PM
ever12
Jun 27, 2011 03:41 PM
aestival
Feb 16, 2009 02:45 PM
bradte20
Jun 15, 2002 01:21 PM
