Brake pads
Old Jul 26, 2006 | 10:23 AM
SwabeLife's Avatar
Question Brake pads
Hello guys,
I'm about to get a new pads. Which brake pads doesn't squeal?
Thanks in advance!
Old Jul 26, 2006 | 10:26 AM
naucrx's Avatar
If installed correctly no street pad should squeal. Make sure to use enough anti-sieze lubricant and reuse the shims.
Old Jul 26, 2006 | 11:48 AM
SwabeLife's Avatar
^what brake pads are you using?
Old Jul 26, 2006 | 01:21 PM
naucrx's Avatar
Right now I have Hawk HPS pads. They make a low-tone hum when I brake at low speeds. But I need new rotors so I didn't bother getting my old ones cut or even sanding them down with 60 grit like I normally do.
When installed properly (with shims, lubricant and rotor prep) I never had any problems with squeaking from: stock Brembo, EBC Green, Project Mu B-force or Ferodo DS2500.
Of all the pads I've used I liked the Ferodos the best, Hawk HPS are a close second.
Old Jul 26, 2006 | 01:25 PM
Wheelhaus's Avatar
I give a nod for Ferodo DS2500's. Streetable, but definitely good enough for aggressive track use. I've had them on two different cars and love em. They squeak a tiny bit when they first touch, but that's it. No pad should squeal loud(unless it's a full blown race pad) as long as you remember to peel off the (kevlar? I still don't know wtf it is) shim that's adhered to the pad. Use it and the metal shim and you're golden.
Old Jul 26, 2006 | 01:39 PM
rsboy's Avatar
stock!
u didn't specify. :P
Old Jul 26, 2006 | 01:47 PM
Smike's Avatar
Haha RSboy
Satisfied GranSports 6s are good. No squeal, braking is excellent.
Look for my write up on the GS5s, Im installing them tonight in about 15mins. Tick tock tick tock. Ill write up something shortly on them.
Old Jul 26, 2006 | 01:48 PM
SwabeLife's Avatar
That's what I'm leaning to, Ferodo DS2500 that is.
thanks guys!
Old Jul 26, 2006 | 02:49 PM
Randy's Avatar
Street honestly I would go with Ferrodo Hawk HPS are good as long as you dont drive agressively
Old Jul 26, 2006 | 06:29 PM
mdosu's Avatar
I have to vote for HPS for street driving as well. Great price for stock performance. Just use anti-sieze and OEM shims and there would be no squeals. HPS is also gentle on the rotors.
It does squeak when it's really cold outside on the first brake situation of the day, and when the pads gets really really hot.
Old Jul 26, 2006 | 06:32 PM
ovelezs's Avatar
I never had squeal with oem pads. Installed hawk hps pads with freshly cut rotors, and have squeal at low speed. It gets annoying sometimes.
