evo brakes
Old Aug 15, 2006 | 09:46 PM
kliker13's Avatar
evo brakes
i have a dum question? i loosened the wrong bolt while changing my brakes. alittle brake fluid came out and i quickley retightened the bolt. what do i do now, if anything??
Old Aug 16, 2006 | 05:30 AM
Fourdoor's Avatar
It is a good idea to change the brake fluid out when you do the pads anyway, so if you already planned on doing that you should be fine. If you did NOT plan on changing the fluid I would recomend that you do so.... when the fluid came out, air may have gotten into the line and you would need to at minimum bleed the brakes to make sure all the air is out of the system.
Keith
Old Aug 18, 2006 | 02:21 PM
DaWorstPlaya's Avatar
Bleed the brakes as Fourdoor said
Old Nov 11, 2006 | 09:24 AM
949's Avatar
949
yes bleed them. get a bleeder nipple to make it easier too.
