Zero lift vs. front lip
Old Aug 23, 2006 | 09:42 AM
dcorn's Avatar
I'd go for something like a Varis lip. I bet their stuff is functional. Do-Luck should be too, most of those companies don't make parts like that for the hell of it.
Either that or get one of those big metal undertray things to stop front lift. It just replaces the stock plastic undertray and you can't even see it from the front. I forget tho makes it though.
Old Aug 23, 2006 | 01:00 PM
trinydex's Avatar
the metal undertrays don't much besides allow the flow to be guided further down the car. the fact is on a car liek the evo eveutally you will hit some jungle of car components under the car. later is better than soon, but you're minimizing losses.
a splitter actually gives you a deck on which to build air pressure and hence create a differential.
the nascar dams both divert air upwards and caust a venturi effect under the car, but they do so at the price of obvious drag.
a splitter causes drag too but it's not obvious drag, it would be ancillary, it would increase the drag on the bumper etc. but it also promotes cooling of the components, which the nascar dam would do also.
so yes that lip is the zero lift kit, as far as i know.
Old Aug 23, 2006 | 05:53 PM
x838nwy's Avatar
Real sorry about this. I'm getting the zero lift mixed up with the front lip on the 9 in my posts.
The pic you posted is the zero lift kit which is similar to the one I have on my VIII. The lip I was talking about for the IX is this one:
Apparently this fits only the IX and actually has a strip of rubber underneath - although I have not seen it personally. I was talking about this one being fixed to the bumper rather than the undertray. I was just getting mixed up in my own typing... sorry...
Trinydex, is the dam in that lip aluminium?
Old Aug 23, 2006 | 10:46 PM
steve_evo's Avatar
If anyone is interested I have the Zero lift kit front lip for sale. PM me and make me an offer...
Steve
Old Aug 23, 2006 | 10:48 PM
x838nwy's Avatar
^would that be the strip of rubber or the actual lip? I'm confused now also - got to stop drinking....
Old Aug 24, 2006 | 12:50 AM
trinydex's Avatar
yes
Old Aug 24, 2006 | 01:30 AM
x838nwy's Avatar
wouldn't that like spark against the road if it scrapes it? I mean going up ramps and stuff?
anyway, is there a formular (and i recall there is) to work out how much load there is on the dam? I'm looking at making my own undertray which incorporates the rubber strip, but I might go with a larger dam and make it from some plastic if I can find out if it's srong enough.
heck, if i find some titanium sheet supplier, I might make the tray from that. Give it a japanese name and sell it for thousands...
Old Aug 24, 2006 | 01:43 AM
x838nwy's Avatar
oh, wait. can i just use Bernoulli's eqn. for the pressure (ro x v^2 /2)?
if it's just a flat plate in section, then I assume it will have detrimental effects if it curves backwards at the bottom? Like, it would sort of channel air towards the bottom?
Old Aug 24, 2006 | 07:27 PM
my-red-rs's Avatar
Air Dam - Zero Lift
All I can say it that a Air Dam works, and you dont need the MITSU part to have one.
See my EVO 8, I made one out of Vinyl "Cove" molding at Home Depot for less than $20. The vinyl is flexible, yet stiff enough to block the wind.
Its only 3.5" above the ground, but it rarely scrapes because it is attached further back on the bumper. If it ever gets distroyed by a parking lot curb, it takes 30 minutes to refabricate.
Old Aug 24, 2006 | 08:41 PM
trinydex's Avatar
^ very cool idea without the hacked nascar look.
Old Aug 26, 2006 | 01:50 PM
WWEVOIX's Avatar
any diy steps or info?
Old Aug 26, 2006 | 01:57 PM
trinydex's Avatar
well the main purpose of the air dam is simply to create a negative zone behind it... and this causes the air to have to speed up to get around the dam and then also this process is expidited because of the negative zone created.
i think the problem with dams is that they're all drag, there's not one part of it that is not drag inducing.
i'd much rather have a splitter type tray that juts out and catches air. at least that feeds your coolers and some of the drag is used for something good.
Old Aug 28, 2006 | 10:10 AM
steve_evo's Avatar
It would be the strip of rubber. I'm asking $100 for the piece, it's about $300 something from the dealer.
It comes with the all the little screws and plates to bolt on.
Steve
Old Aug 28, 2006 | 11:55 AM
mdosu's Avatar
^pmed
Old Oct 1, 2006 | 10:07 AM
.MM's Avatar
.MM
very easy solution to this problem
if you lower the car an inch, you wont need the zero lift kit
