problem with stance coilovers
Old Aug 21, 2006 | 03:06 AM
WWEVOIX's Avatar
any one getting excessive clunking noise in the front with these? and how long it takes for the springs to sit in?
Thanks
Old Aug 21, 2006 | 03:48 PM
hokiruu's Avatar
are asking how long it takes for spring to settle? most springs do settle a little, but usually don't make lots of noise. changing to a pillow ball solid/spherical mount will definitely increase the likelihood of having noises etc. is it all the time? what about when you're turning? how did you set them up?
Old Aug 21, 2006 | 07:30 PM
ashumo's Avatar
it would help knowing when your clunking. time for springs to settle...a day or so (300 miles)? have you talked to STANCE or your vendor?
check your sping seats and seat locks (perches), also check your upper mount nut for proper torque, and if you have adjustable camber plates check to see if the locking blots are torqued.
Old Aug 21, 2006 | 10:45 PM
hokiruu's Avatar
Ashumo is right. Who/where installed them? There are tons of reasons they could be clunking. Your best bet is to get it in the air and check it out.
Old Aug 21, 2006 | 11:12 PM
WWEVOIX's Avatar
nevermind, got it fixed
thanks
Old Aug 21, 2006 | 11:26 PM
hokiruu's Avatar
Well, what was it? I'm just curious.
Old Aug 22, 2006 | 06:46 AM
Drifto's Avatar
What do you think about them?
Old Aug 25, 2006 | 08:09 PM
WWEVOIX's Avatar
just a lose bolt, the shop fixed it. Well they are great, inverted fronts and mono tube design, the specs are similar to the cusco's(zero r) i think, i forgot which model...
