Adjust upper pillow mounts/camber plates
Slide the top of the strut inward toward the engine. You should ony do this on an alignment rack or you could end up with too much/uneven negative camber. Plus any time you change the camber you need to adjust toe or the tires will scrub and wear out very quick.
