Lost Rays wheel lock key + flat tire= tow and ?????
Old Sep 12, 2006 | 04:32 PM
#2 SM's Avatar
Question Lost Rays wheel lock key + flat tire= tow and ?????
Scholars,
I ran a search and came up empty...
Here's my dilemma: I have Rays racing lug nuts (the ones that fit over ext. studs) and have lost the wheel lock key . After the pride swallowing realization of this fact and a quick tow to my house, I still have one flat tire presumably "stuck" on the car.
Question 1:
Is there any vendor that can overnight me a RAYS racing wheel lock key (preferably separate from another set of lugs)?
The wheel lock looks like any other lug nut except for on one "face" there is a ridge about 1 mm wide preventing a regular 21 mm socket to fit onto it. The wheel lock key looks like any other 21 mm socket except for a perfect groove in one of the faces to match the wheel lock...
Question 2:
Assuming quick delivery of a new key is out of the question, is it possible to remove the wheel lock without damage? I have heard of a few methods that I have yet to try in fear of damaging the wheel or the wheel lock. One suggests using a deep faced 20 mm 12 pt. socket and "tapping" it onto the wheel lock enabling just enough torque to break tension. Another suggestion involves a pipe wrench, a cooler full of beer, 2 strippers, and Tylenol.
What would you suggest?
Thanks ahead of time.
Seth
Old Sep 13, 2006 | 12:50 PM
hc434's Avatar
I dont' think the locks are standardized, right?? You'd have to get a specific key for the specific set of locks you have which should be indicated by a serial number somewhere. And usually, if you ahve the serial number,thenyou can just order that key lock through Rays.
Old Sep 13, 2006 | 12:56 PM
PVD04's Avatar
If you can get to the ridge with a file or a grinder without damaging the wheel you could try to take it off. Trying to jam a socket onto it could also work. It would likely damage both the lug nut and the socket, but it would help with your dilemma.
-Paul
Old Sep 13, 2006 | 01:26 PM
MondoBongo's Avatar
call around to a couple local tire shops. they might be able to get the locking lug off for you if you cannot get the key quickly.
Old Sep 13, 2006 | 01:45 PM
#2 SM's Avatar
Thanks for the responses guys. I picked up 12 pt. socket set today that includes 19 and 20 mm. I should be able to tap one or the other on and apply enough torque to break tension without causing too much damage.
I'll update the thread when I am finished.
Thanks again.
Seth
goforwand
For Sale - Wheels / Tires
May 7, 2017 08:33 AM
Evodetailer123
Dec 1, 2016 07:34 AM
katchup
14
Mar 13, 2012 02:26 PM
A-SPEC
Vendor Classifieds
30
Aug 22, 2011 09:58 AM
vtluu
Jul 24, 2005 08:33 PM
