Stiffest Front Bar
Old Oct 2, 2006 | 03:04 PM
sonicnofadz's Avatar
If springs are not allowed but shocks are, upgrading the shocks will benefit handling far more than just sway bars.
Old Oct 2, 2006 | 05:38 PM
BigEvoAS's Avatar
Originally Posted by Mr Chef
You might get the type of response you're looking for in the Motorsports forum:
Yes, much better.
Theres even a thread about stock class setups:
https://www.evolutionm.net/forums/sh...ad.php?t=57489
That's the ticket!
Old Oct 2, 2006 | 05:51 PM
BigEvoAS's Avatar
The car does pretty well with stock struts except for when the bumps become large enough to unsettle the front. Then it takes a long time for it to settle back down and we do lose time there. I'm a bit of a shock snob, so I'm well aware of the improvements that a good set of dampers can make. It's just not in the owner's (Ro, on this board) budget right now.
We are trying to make inexpensive, incremental improvements in the car, and attacking the tricycling and non-linear response seems like a good start.
Old Oct 2, 2006 | 06:11 PM
Gabriel J's Avatar
Originally Posted by Matt2.8NJ
*crickets chriping*
http://www.scca.com/Event/Result.asp?Ref2=338
Unless I can't read worth a damn, I don't see any Evo's in AS. Only STi's.
That's because all the evos go straight to BSP..and do quite well.
The sti's usually head to street mod
Old Oct 4, 2006 | 06:58 PM
finallyevo's Avatar
wow what is involved in the install of a front sway bar
Old Oct 4, 2006 | 07:20 PM
Not much, unbolt the two end links (one bolt each), then undo the two support braces (two bolts a piece) for a total of 6 bolts.
Old Oct 4, 2006 | 07:42 PM
EVOIXMR8916's Avatar
i say cheat and buy a rear swaybar and paint it oem black and take atvantage of it....lol...
Old Oct 5, 2006 | 07:21 AM
RallySport Direct's Avatar
Silver Sponsor
It takes alot more then that.
You have to drop the front rack down about 4" at least. There is a write up somewhere. I say give yourself 2-3 hours for install.
