Tanabe Sway Bars
Old Oct 5, 2006 | 01:52 PM
EVO-IX-MR's Avatar
Tanabe Sway Bars
I was wondering if anyone has used Tanabe front/rear sway bars either individually or as a set. If so what has been your experience with them?
I have been thinking about getting them for my IX MR along with Tanabe GF210 springs and Tanabe front/middle/rear lower arm bars $1,300 installed at Axiom.
After reading the forums it seems like a lot of well respected suspension guys like Robispec recommend a 24mm or bigger adjustable rear sway, spring combo with no front sway.
It no doubt would be best to go with a setup from someone like Robispec who specializes in suspension ($1,600 for suspension basic from Robispec), but would the Tanabe setup above be bad or waste of money for someone who will drive 80/20 street/track like me?
Thanks for the advice in advance!
Tanabe sway specs and link bellow:
http://www.tanabe-usa.com/stabilizers/
Front diameter:25.4
Rear diameter:22.0
Old Oct 5, 2006 | 03:27 PM
GTWORX.com's Avatar
Increasing the front to 25.4mm and the rear to only 22mm does not sound like a great solution to me. Plus, I like an adjustable rear sway, as it gives you at least a little bit of easy fine tuning you can do yourself.
I think overall it may be an improvement, but i know you could get a lot more out of a lot less money.
Just my thoughts as i'm waiting for my pasta to cook.
- Andrew
Old Oct 5, 2006 | 10:32 PM
EVO-IX-MR's Avatar
Yeah I really started thinking it wasn't a good idea when I found out the size of the sways. Tanabe doesn't list that spec anywhere, I had to do some searching to find out. They do say something about the material their sways are made of makes them uncomparable to other sways. Sounds a little like BS to me.
There is probably a good reason not many other people are using Tanabe sways
Thanks,
-Josh
Tanabe USA
Feb 20, 2014 09:52 AM
RavSpec
Evo 'For Sale' Suspension / Brakes / Handling
18
May 14, 2010 10:19 PM
Joe@robispec
50
Oct 10, 2009 08:18 PM
06mr775
May 7, 2009 01:50 PM
500whp.com
Jan 27, 2006 02:55 AM
