Rota P45Rs...
Old Nov 9, 2006 | 08:09 PM
--anonimuz's Avatar
Rota P45Rs...
Ok I've searched... but I really didn't get my questions answer right now I'm on Tein S. Tech (2" drop) and I am planning to get these wheels... I now these will fit and read that I would have to have camber plates to run these wheels? or my lowering springs alone will do without adjusting my camber? Help me out pls! I'm confused...
Old Nov 9, 2006 | 08:13 PM
ForcedFedRS's Avatar
If you are going with the 18x9.5 I believe you will have to roll your fenders have a decent amount of negative camber for these wheels to fit. So depending on your camer situation now, which probably isn't much, you may need more, but I'm not %100 sure.
Old Nov 9, 2006 | 08:21 PM
VIIImylunch's Avatar
i had the stechs with 18x9.5 and i had to have my rear fenders cut. The fronts were fine.
Old Nov 9, 2006 | 08:32 PM
--anonimuz's Avatar
any rubbing at all? what was the size of your tires? aw and wat was the offset?
Old Nov 11, 2006 | 07:57 PM
offset was 35. tire size 265x35x18. I have slight rubbing on full crank.
mikemike396
95
Apr 27, 2020 09:56 PM
dpole96
Nov 26, 2014 02:14 PM
turbotsi
11
Jun 26, 2013 08:18 AM
pcamaliga
Sep 18, 2012 02:35 AM
