Brake Light Under Braking ???
Old Nov 29, 2006 | 03:34 PM
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
Hey guys my brake light comes on (you know the one that lights up when you pull your e-brake) when Im braking semi hard or hard. Anyone got any ideas? It just started this out the the blue. Im also running stock brakes with DS2500 pads and Stoptech lines.
Old Nov 29, 2006 | 03:37 PM
BlackIX's Avatar
Check your brake fluid level. Sometimes when it gets close to the low mark on the reservoir it will slosh around when braking or accelerating and make the light come on. Then once your stopped the fluid will level out again and the light will go out.
Old Nov 29, 2006 | 03:40 PM
M3this's Avatar
^ yep that was it ... it was low as I for got to add fluid after I regreased the pads.
