nt03 fitment
nt03 fitment
i have been reading everything i can find, pming everyone with these wheels and vendors who sell them but i cant get a difintive answer on fitment
here goes again
i want to run 18x9.5 Enkei NT03. there are two offsets. +27 and plus +40. it seems like the +27 is the best fitment.
can i run the 18x9.5 +27 with just spacers in the front? will the back need to be shaved, rolled ect?
what size tires.. seems like 35 height is neccesary, so 255. 265/35/18?
others are running a combo, +27 in front +40 in rear (evodave?) would this fit better with no rolling or would that be more work? how do you rotate tires in staggered offsets?
o i forgot. stock suspension right now. i would like to lower my car on swift springs. will that make a diference in fitment?
maybe i am getting in over my head with such a wide track ready wheel.. all your help is apreciated. and thanks to all of those who have helped me already
here goes again
i am almost certain youll run a 18x9.5 +27 with a 12mm spacer for front and 18x9.5 +27 no spacer for the back. 265/35/18 tire
ill try and find a pic for you
awesome. if thats ligit im buying these wheels in silver. how rough of a ride are 35 tires going to be? i mean i know evos arent about luxury but if the ride gets too much worse girls are going to kill me
dont know about the ride quality, i am sure it will be a little stiffer. but after some searching for you i found you are probably best to go with a +40 offset in the rear, and 255/35/18. youll still have to get the fenders rolled.
here is a pic i think he is running a +27 in the rear.
check out post 20 of this thread....sickness....https://www.evolutionm.net/forums/sh...highlight=nt03
Jim, I'm actually in the process of putting NT03+M size 18X9.5 w/27 offset all around.
I was told that I need 10mm spacers for the front.
As far as I know, I don't need any spacers for the back.
I also thought about staggered set up but i wanted to be able to rotate the tires.
I was also told that I need to roll the rear fenders.
I'm planning on going with 255 35-18s w/springs from gtworks when they come out.
I'm still in the process of obtaining all the parts.
Good luck.
Good luck.
thanks for the help. seems like +27 is the way to go. now i just got to get the springs, roll the fenders and buy some 255s. that is, after i get my evo back from the body shop
