Wheel alignment for KW V3s
Old Dec 21, 2006 | 12:22 AM
sanjaya1's Avatar
Hi. I was wondering if I can get some help. I got KW V3s installed by TT a couple of weeks ago. I don't have camber plates yet. I haven't done the alignment yet either. I realized that my front tires (which were worn a bit) have almost completely worn out in the middle. I got new tires on order (same tire, S03s). I am running 245/40/18s. I was looking for some feedback on a good alignment spec for street use, that doesn't kill my tires too quickly. My Evo is my daily driver, and I put a lot of miles. Thanks.
Old Dec 21, 2006 | 12:33 AM
Silk's Avatar
I personally run -2.0 in front and -1.5 in back with no toe at all. It has a real nice neutral feel too it and is easy on the tire wear as long as your push in in the corners once and a while. Toe is what kills your tires alot more than camber
Old Dec 21, 2006 | 12:41 AM
smokinxtreme's Avatar
i suggest that you go dwn to westend alignment in Gardena or Robi-spec in AppleValley since he carrys KW and you know the rest.
Old Dec 21, 2006 | 01:19 AM
sanjaya1's Avatar
I assume West End has experience with EVOs? I guess it will be a question of which outfit I can schedule and get to without too much hassle during the holidays. Do you guys know if I can run -3 deg of camber without camber plates? Thanks for the feedback.
Old Dec 21, 2006 | 01:30 AM
may be not so go see Robi and he'll take good care of you.
Old Dec 21, 2006 | 07:58 AM
GTWORX.com's Avatar
What are your spring rates? Are they custom or the standard rates?
- Andrew
Old Dec 21, 2006 | 10:03 AM
sanjaya1's Avatar
I have the standard settings KW sends preset. I want to keep it streetable, and in SoCal that means dealing with a lot of pot holes.
Old Dec 21, 2006 | 10:36 AM
robi's Avatar
call me I can fix both the alignment and the spring rate issue.....7609124337
Raptord
Oct 31, 2016 10:36 AM
Evo_AK
Nov 27, 2015 01:14 PM
jd888jd
May 12, 2011 03:01 PM
Mad_SB
18
Jul 13, 2008 10:57 PM
mexicanevo
11
Jan 25, 2008 07:15 PM
