06 mr suspension on 03, alignment question??
Old Dec 28, 2006 | 10:10 AM
NYEVO8's Avatar
i purchased a complete stock 06 mr suspension from a member on this forum to put on my 03 that had the knocking front end problem that many people complain of, and it worked 8000 miles later no cluncking.
question is, when i installed it i got a alignment with 03 specs, should i have gotten a alignment with the specs of the 06 mr? i read somewhere that there is a diffrennce in ride hieght from the 03 suspension to the 06 mr, it was minimal but everybody knows that every little thing affects how these cars behave.
does anybody know which alignment specs i should go with?
Old Dec 28, 2006 | 10:19 AM
Smike's Avatar
If you have an 06 MR susp. Id do it to the 06 specs. Personally, Id set the tow to zero though.
Old Dec 28, 2006 | 10:24 AM
TxEvo8's Avatar
yes definitely use the 06 specs...
Old Dec 28, 2006 | 10:48 AM
GTWORX.com's Avatar
Do zero toe front and rear, and set negative camber to -1 to -1.5 up front and -1 in the back.
- Andrew
Old Dec 28, 2006 | 10:57 AM
gsrboi80's Avatar
- Andrew
Thats what I run
Old Dec 28, 2006 | 11:03 AM
GTWORX.com's Avatar
It's nice for a street car isn't it?
- Andrew
Old Jan 9, 2007 | 07:15 AM
NYEVO8's Avatar
thanks for the replies, i am going today for the alignment,
quick question for you guys that responded with actuall numbers, is that what you think is good for the 06 mr or for all year evos?
Old Jan 9, 2007 | 08:34 AM
GTWORX.com's Avatar
All years, for a street run EVO.
- Andrew
Old Jan 9, 2007 | 09:09 AM
NYEVO8's Avatar
thanks
iseedipp
18
Jan 20, 2016 11:48 PM
Bladey
Dec 30, 2014 06:33 AM
RussK3
10
Jun 28, 2010 07:10 AM
Bounty Hunter
Dec 7, 2009 04:15 PM
06MR6
15
Jun 5, 2007 01:34 PM
