All 4 tires need to be same size?
Old Jan 5, 2007 | 10:25 AM
LancerEVOmann's Avatar
I have Tein H-techs and my front tires rub on the outside only when I turn left or right all the way. The tire size is 245/40/18. They were fine when the car was stock. I just ordered 4 225/40/18's cause I assumed all 4 tires need to be the same size. Is this true?
Also for sale are 245/40/18 Nitto Neo Gen's...have 5k miles on them. Front 2 have slight rubbing where on outside of tire (about 1/2 a figure nail) still in great condition, rear tires are fine. Will sell for $75 each plus shipping, I paid about $135 each for them new.
Old Jan 5, 2007 | 10:28 AM
TxEvo8's Avatar
Not only do they need to be the same size, but they need to be relatively close in wear. You should always replace 4 tires on an AWD system.
Old Jan 5, 2007 | 10:30 AM
Roldy's Avatar
The overall diameter of the tires also needs to be similar if not same to the stock tires.
Old Jan 5, 2007 | 11:28 AM
Neal@tirerack's Avatar
+1 to the above. here's some more info on matching tires on AWD vehicles
Matching Tires on Four-Wheel Drive And All-Wheel Drive Vehicles
evo150's Avatar
did you try rolling the front fenders to gain clearance for the 245/40/18
Old Jan 5, 2007 | 11:30 AM
ddcha's Avatar
width doesn't have to be the same (i.e., the back can be wider than fronts) but the diameter must be the same between the front and the back.
Old Jan 5, 2007 | 11:32 AM
Danny23's Avatar
misunderstood post
Old Jan 5, 2007 | 11:33 AM
mac_05evo's Avatar
What offset are your wheels? Sorry to be off topic just curious though as my car is lowered on Hotchkis springs and I was going to run 245/40R18s on my new wheels..
Old Jan 5, 2007 | 01:10 PM
evo150's Avatar
what wheels and size are you getting? if you go with a falken tire there usually isnt any problems (depending on rim choice) do to having a rounded shoulder
Old Jan 5, 2007 | 02:07 PM
mrMTB's Avatar
The reason that they need to be the nearly the same diameter is that differing sized tires will roll a slightly different distance for every revolution. The differentials will treat this as if the vehicle was turning. If you have an LSD it is worse since the LSD will work to send more power to the wheel which is not turning as quickly. This will toast your LSD in short order.
Old Jan 5, 2007 | 02:41 PM
No, I had thought of it, but how do you do it?
Old Jan 5, 2007 | 02:47 PM
I don't know, the car came with 18" Privat Fahren rims and I think they are not made anymore.
Old Jan 5, 2007 | 03:15 PM
mrMTB's Avatar
http://www.rollyourfender.com/index.html
Old Jan 5, 2007 | 05:26 PM
Originally Posted by mrMTB
My tires aren't hitting the fender lip, they are hitting the middle of the wheel well.
Old Jan 5, 2007 | 07:02 PM
mrMTB's Avatar
Do you mean to say that they are hitting the plastic fender lining in the middle?
