18x9.5 Work Emotions +20 offset
does any one know if the 18x9.5 Work Emotions with +20 offset would fit i need to know from some one that maybe had them or know anyone that did??
this guy is selling a set but not to sure if they would fit i pm couple of vendors they said rolled fenders in the back and front wider fenders?? i never seen anyone have them untill he posted
https://www.evolutionm.net/forums/sh...d.php?t=249189
HELP anyone with any info i really like these wheels but wanted to make sure i can get them on some how
planning to run 255/35
I don't have experience with that specific offset or wheel, but I do have experiece with how a +24 offset fits.
As long as you run 255/35's and no wider you should be ok. You will have to roll/pull the rear quarter and mayby pull the front slightly. Also, more neg. camber will help tuck them in some. I'm guessing this is for pure show and not racing since you are planning on running 255's..so running around with too much neg. camber on the street will not be of any benefit, but only make tires wear faster. Maybe run -2f, -1.3r.
They won't be an easy fit but it can be done with some work.
contact voidhawk....he has 18x9.5 work emotions on his car with 275/35/18. i just dont know the offset he is running. check out post #67 of this thread https://www.evolutionm.net/forums/sh...=135723&page=5
edit: after reading the thread he is running a +38 offset too, with a 20mm spacer upfront
here is a link to 18x9.5 +38 offset 5mm spacer up front and 265/35/18 tires https://www.evolutionm.net/forums/sh...+work+emotions
Big big difference. For one thing the Stoptechs on the car in the link you posted give more clearance than the stock Brembos. The Stoptechs caliper isn't as thick/wide overall. That allows him to run an effective offset of +33 in the front. With the Brembos you need an effective offset of around +25. For the rear the range of +33 to +40 is perfect. It'd be an entirely different setup trying to fit up the an 18x9.5 +20.
I just spoke to WorkWheelsUSA/Toda Racing and they said the 18x9.5 +12 would be the only one that would fit without a spacer. The +20 will still require a spacer in the front, just not as big as the +38 would require.
the +20mm offset and 9.5" will make you do some huge pulling on the rear fenders. In the picture on the other thread you can see where they have pulled the rear fender out so much it has creased the quarter
Wow guys, I just ran across this. First off, the car in the pic is running the wheels WITHOUT a spacer. Yes, it is the +20 offset. I dont know where you guys get this stuff, but damn, thats not right. The guy who said you can see the fender "pulled" in the rear is wrong. There was NO fender pulling, just rolled the lip up. They are an aggressive fitment, its for someone who wants something different, something not everyone has. Its not your typical flat Emotion. I personally think you guys shoud jump on this deal
boostingevo here is a thread i found for you http://evolutionmr.net/forum/viewtop...ighlight=#5116
