Wheel Stud
Old Feb 25, 2007 | 12:18 PM
keevo54's Avatar
Wheel Stud
I broke a wheel stud today doing a tire rotation. I don't know why the lug was so hard to get off because it was tightened by hand. I got it loose and turned it once and the lug got really hard and then broke.
I searched and saw a few threads but needed to make sure I was going tyo fix it right.
Is it ok if I dtreet drive with a broken stud? My plan fr install is to buy a new lug and stud from the dealership. Hammer out the old stud and the slide in the new stud. I have seen posts by people who did it this method then others say the rotor need to be removed; does anyone have any advice?
Old Feb 25, 2007 | 12:19 PM
~EVILEVO~'s Avatar
checker sells the studs for $3.00 hammer the old one out and hit the new one in.
GL~
Old Feb 25, 2007 | 12:36 PM
keevo54's Avatar
GL~
Where does the wheel stud come out? I will take a picture in a minute, but I just don't see where it will fall out.
Old Feb 25, 2007 | 12:49 PM
keevo54's Avatar
click for higher resolution
Old Feb 25, 2007 | 01:50 PM
jbrown's Avatar
You have to remove the wheel hubs to do it right. It's not really as tough as it sounds. Probably about an hour or so to do both front hubs. I haven't done my rears yet.
For the fronts, first you pull the wheels, calipers, rotors, and dust shields. Then the big axle nut (27mm???) Then 4 bolts on the back side of the hub.
But I wouldn't just use a hammer. If you don't have access to a press to do it right, I would suggest having the dealer do it.
Old Feb 25, 2007 | 03:54 PM
keevo54's Avatar
after more research I think I will need to remove the caliper and rotor; then hammer the old stud out. For reinstall, I will put the new stud in and then use a spacer and tigthen an open nut till the stud is seated. I think the guys who were able to do the install with the rotor still on were regular lancers.
Old Mar 3, 2007 | 02:55 PM
keevo54's Avatar
I tried to hammer the stud out with a rubber mallet and it would not budge. I hit it relatively hard. WD-40 is now soaking in. Does anyone have any advice or can recommend where I can get a suitable press? I do not want to hammer a lot or two hard b/c I am afraid of damaging the wheel bearings. I really do not want to take it somewhere now that the caliper and rotor are off.
Old Mar 3, 2007 | 03:20 PM
Profoxcg's Avatar
subscribed... as i have to replace all my studs eventually....
a DIY w/ pics would be great.
Old Mar 3, 2007 | 04:45 PM
keevo54's Avatar
early bump but I want to fix it tonight
Old Mar 3, 2007 | 05:55 PM
keevo54's Avatar
Someone on another forum said i should heat up the stud, but that doesn't sound too good to me
Old Mar 3, 2007 | 06:53 PM
Profoxcg's Avatar
I have a question... doesnt any aftermarket place sell studs for the evo - that would be stronger and maybe lighter?
I remember I was going to put something like that on my civic at one point from I think Skunk.
http://www.skunk2.com/Merchant2/merc...roduct_Count=7
Old Mar 3, 2007 | 07:31 PM
Frenchy4g63's Avatar
AMS has ARP wheel studs
Old Mar 3, 2007 | 07:59 PM
Profoxcg's Avatar
and I guess i need open lugs... who makes those? / would they work with the stock wheels?
anyway can someone answer my question in regards to the hub?
Old Mar 3, 2007 | 08:16 PM
SilverShadow03's Avatar
If you have a strong drill bit & drill.... you can drill it out.....i had this happen on my Acura. Not as easy to put back in but I got it in.......no press......bleh....use a heavy hammer.....it helps. Rubber mallet wont help you on this one.....
Old Mar 3, 2007 | 08:34 PM
keevo54's Avatar
The more I like the more people are saying to use a 3-5 pound hammer. Are the wheel bearings at risk if I only hammer out one stud?
