thump when braking
Old Jun 1, 2003 | 09:49 PM
chrisitr's Avatar
thump when braking
When I brake hard and the ABS kicks in there is a thump in the car. It sounds like I ran over something and it hit the bottom of the car. I don't know if this is normal or if I should have it checked out. Has anyone else experienced this?
Old Jun 2, 2003 | 12:45 AM
Diesel's Avatar
normal for ABS... they are very loud when activated...
i've yet to experience ABS on the EVO yet though...
Old Jun 2, 2003 | 01:17 AM
ez76's Avatar
I have experienced this when braking hard as well as when accelerating over rougher terrain (not so rough that the car might bottom out or anything, though).
Suspension clunkiness?
Old Jun 2, 2003 | 02:08 AM
Diesel's Avatar
i'm experiences some clunks form my suspension since i installed the Eibachs, but maybe it's an inheret trait of the EVO...?
Old Jun 2, 2003 | 02:09 AM
Diesel's Avatar
holy ****, i need to start proofreading my ****...!
Old Jun 3, 2003 | 01:27 AM
superz's Avatar
yep, i've heard the same noise at full a.b.s activation. It only happens when the front suspension is at full compression, nose dive. I put the car on my lift to inspect it and found nothing. Only thing that I found was that maybe on full compression the sway bar makes contact with the frame. Not positive yet. Sounds nasty as ****, like something metallic just snapped!!
Old Jun 4, 2003 | 11:28 AM
mason@tirerack's Avatar
Is this the "thump" sound that the car makes when hitting the brakes hard and entering a corner...sounds like loose suspension or something?
