RobiSpec to Omaha!
Old Mar 2, 2007 | 04:28 PM
Ookami's Avatar
Originally Posted by robi
STL is right on my route...if I'm driving...is it closer for the Omaha gang than Chi town?
robi
If you were unable to make it to Omaha I'd rather drive to Chicago over St. Louis.
Old Mar 7, 2007 | 11:22 AM
Ookami's Avatar
1) Ookami (bumpsteer,rear bushings, install, cornerweight, align)
Purchased used RobiSpec KWv3s so I'm looking to make this happen, let's make a list for Omaha with what we want done.
Old Mar 7, 2007 | 12:54 PM
speedomodel's Avatar
1) Ookami (bumpersteer,rear bushings, install, cornerweight, align)
2) speedomodel (front roll-center, steering precision, and alignment)
Old Mar 7, 2007 | 02:26 PM
DaWorstPlaya's Avatar
3) DaWorstPlaya (rear trailing arm bushings, ride height, corner weight, alignment, maybe install?)
Old Mar 7, 2007 | 04:15 PM
robi's Avatar
Just got a call for a V3 setup from lincoln...How bout a I arrive on the first thursday of april and get you guys setup....on my way to chicago?....
Speedo the rollcenter kit does what the steering kit does for bump steer and I'm not dropping a front Xmember without a lift!....the rest we can do from the floor....how late will the neighbors let me work?
Old Mar 7, 2007 | 06:00 PM
Ookami's Avatar
Thursday afternoon on April 5th works for me!
Old Mar 8, 2007 | 08:30 AM
I would be down with that ... Where would the install be done Lincoln or Omaha? ... Speedo, are you going to rent a lift?
Old Mar 8, 2007 | 09:57 AM
No, are you? That date sounds fine to me. As Robi recommends, I won't be getting the steering precision kit installed.
Old Mar 8, 2007 | 11:26 AM
Ookami's Avatar
Old Mar 12, 2007 | 09:04 PM
Ookami's Avatar
1) Ookami (ground control front camber plates, rear bumpsteer kit, rear trailing arm bushings, install, cornerweight, laser align KWv3s 7k/8k) [deposit sent]
2) speedomodel (front roll-center and alignment)
Old Mar 13, 2007 | 10:56 AM
robi's Avatar
Everything hinging on the "v3" from lincoln...at this point...
Old Mar 19, 2007 | 08:50 PM
Ookami's Avatar
Any updates on Omaha happening? if not ... details on the Chicago trip so I can make plans. Thanks.
Old Mar 19, 2007 | 09:35 PM
robi's Avatar
looking like Chicago.....unles someone pops up....
Old Mar 20, 2007 | 01:05 PM
Sorry guys I have to back out as I'm having trouble re-valving my Ohlins to Vishnu specs ... looks like I won't be getting my coilovers on til May
Old Mar 20, 2007 | 01:26 PM
That sucks. So you spent all winter talking about getting it done, and not doing it. As Arnold would say: "You lack discipline!"
