what lugs do u recommend?
Old Mar 5, 2007 | 12:39 PM
t51splbb's Avatar
Originally Posted by jbrown
All those $100+ lugnuts are great if you have money falling out of your pockets and can afford to buy 2 sets from the beginning so you'll have a spare key and spare lugs for when they are lost and/or broken.
Otherwise the Muteki and Kyokugen only weigh a few grams more, cost 75% less, use a standard key, and are 10x more durable.
FYI,you can buy the keys for the locking Rays lug nut separately. I do however agree with you on the durability of the cheaper ones mentioned. Durability however only becomes an issue if you over torque the lugnuts which shouldn't be done whether they are made of steel or aluminum.
Old Mar 5, 2007 | 03:50 PM
jbrown's Avatar
The only reason I suggested buying 2 sets right off the bat is that it seems like no one ever has just the keys in stock, and you can't always afford to wait 6-8 weeks to get one special-ordered from Japan.
And yes, in a perfect world where you are the only one to ever torque your lugnuts and you remember to use anti-seize, and you never bring it to the dealer or a mechanic for service, or you have the only mechanic on the face of the earth who cares enough to use a torque wrench instead of an impact gun, then I agree, duribility will not be a problem. Otherwise, you're flushing money down the toilet.
Old Mar 5, 2007 | 06:58 PM
SPANKED's Avatar
Good info... I need lugs... thanks everyone.
Old Apr 18, 2007 | 10:11 AM
alby988's Avatar
mcgard spline drive seems liek a good choice for the money as well.
Old Apr 18, 2007 | 10:31 AM
wz1999's Avatar
Kics R40
Old Apr 18, 2007 | 02:11 PM
chaotichoax's Avatar
had them on my sti and now my evo
they offer lock nuts as well as regular nuts
they have a rotating base and are available from subydude.com for about 100 shipped
Old Apr 18, 2007 | 07:12 PM
YELOEVOVIII's Avatar
a company called goldenapple has a nice set of light weight luts .23g ea had a set on my old civic worked great. you can get them from discount tire co
Old Apr 18, 2007 | 09:06 PM
EVOlutionary's Avatar
Originally Posted by wz1999
Kics R40
+1
The Kics are sweet. They have a built-in washer/rotating collar. When you tighten them down the collar stays pressing on your wheel rather than spinning with the rest of the nut so they don't F up the finish on your rims. Plus they are supposed to give a more reliable and repeatable torque reading. Downside - they are $$$
EVOlutionary
Old Apr 18, 2007 | 10:11 PM
jkim1201's Avatar
I'm using Muteki, so far no problem.
selp
Jan 15, 2013 09:23 AM
Profoxcg
Feb 8, 2007 09:42 PM
Resonance
Jul 21, 2006 11:22 AM
MEVO
31
Mar 30, 2005 10:42 AM
justchil
Jul 18, 2004 08:33 PM
