Widest Wheel I Can Fit?
Old Mar 9, 2007 | 06:11 AM
markdaddio's Avatar
For street use, I would run a 18x9.5 35mm give or take a mm on the rear, and 18x9.5 with a 25 mm offset give or take a couple mm. If you are looking to be able to rotate tires, 35mm give or take a mm with 18x9.5 using a 10mm spacer up front with a 265/35/18 would be my choice. The 285/30 tire in the rear requires fender lip rolling to make it work. Hope that helps.
Mark
Old Mar 9, 2007 | 06:33 AM
Nikolov09's Avatar
Lightbulb
Mark - that helps alot ... and for the wheel spacers... can you better explain that theory, alot of people claim that a wheel spacer reduces the handling of your car... now i understand that they have 10mm wheel spacers, and i acknowledge that 10mm is very slim.... but wouldent you be able to substitue a wheel spacer with a good offset? .... Moral of the question - why do people put wheel spacers when there are proper offsets?.....
Thanks ~ Steveo
Old Mar 9, 2007 | 06:55 AM
Kodiak's Avatar
I run 17X10's but with a 13mm spacer front 3mm back. Had to get extended studs in front. https://www.evolutionm.net/forums/sh...d.php?t=207744
Old Mar 9, 2007 | 07:36 AM
Torre from Va.'s Avatar
Originally Posted by Nikolov09
-Torre - lets hope EVO-L can come in here and give us some insight.. or maybe you have some links to his pictures torre
Here's one of the links
https://www.evolutionm.net/forums/sh...&highlight=CCW
Old Mar 9, 2007 | 07:52 AM
markdaddio's Avatar
Thanks ~ Steveo
The reason you would run spacers would be so that you could rotate the tires without having to get them remounted. I don't believe that it is possible to run a 18x9.5 rim of the same offset, and have it fit both front and rear, hense the use of spacers. If you don't care about rotating tires, then just order the correct offset rims for front and rear, and no spacers would be necessary.
Mark
Old Mar 9, 2007 | 07:57 AM
Nikolov09's Avatar
Kodiac - thanks for setting your car as an example, those 17x10 are nasty bad... great choice
Torre - lol that is a sickkkk @$$ link, provides good info, and has a SIIIICCKKK 18x10 example, even though the CCW rim would not be my first pick, but great example
Mark - that helps alot thank you very much
~ with all this info i should be ordering my rims by tonight lol
Thanks ~ Steveo
Old Mar 9, 2007 | 09:48 AM
el producto's Avatar
http://www.youtube.com/v/DfaVxdbe1es
Old Mar 9, 2007 | 01:38 PM
Nikolov09's Avatar
Thumbs up offsets
i have done research in offsets..... is there any ONE certain type of offset that is best suitable (best performance) for our car(s).... or is it just personal preference on how *far out or how *far in* the wheel will be presented?
that being said, since we all have figured out that you can do a 18x10 (just like EVO-L and his CCW rims) ... what would be the best offset for a 18x10 to fit our Evo's?
-by the way lets get some offsets without any spacers needed
~Thanks Steveo
Old Mar 9, 2007 | 01:45 PM
1fastevo8's Avatar
Could you run an 18x9" wheel without any problems for daily-duties?
Old Mar 9, 2007 | 02:25 PM
rjdevo9_mr's Avatar
your offset will play a role in how wide you go as well...i'm running 18 x 9's with an 18mm offset and rolled my rear fenders---it rubs occassionly when i'm carrying a full load of people
Old Mar 9, 2007 | 02:34 PM
DarksideEng's Avatar
Hey, I just noticed this thread. I believe the offset for the CCW's was 44mm. Then I ran a 15mm up front, and an 8mm in the rear. Front spacer was for the Brembos, and the rear spacer was for the control arms. I have another set of Work wheels coming in that are 18x10, they should be here by the end of the month, and I will post pics up. As far as the CCW's went, they did not rub at all, and I didnt even have to roll the rear fenders. I hope that helps! Any more questions I will be glad to answer.
Old Mar 10, 2007 | 01:12 AM
Nikolov09's Avatar
Thumbs up Yeezz Zirr
Evo-L ..... that helps allllot, i just have one more question... do you know of any offset that you wouldent have to run spacers?.....
RideEvo9- lol dude i totally know how you feel with that full load crap.... im taking out my rear seats..... it gets ridiculous, im always driving... but that is giong to change real damn soon
Work Wheels is a great choice, im leaning towards the Volk 28N..... reason being is that in my research i found out that the Work Wheels and the ADVAN Wheels are both Cast.... and the VOLKS are forged.. ( for people that arent familiar.... Since the Volks are forged.... that makes them lighter and stronger)
-I would with out a doubt in my mind go with the WORK EMOTION and also the ADVAN RC2, over the VOLK 28N.... but like i said again Volks are forged.... well what im basically trying to say is .... the ADVAN and WORK... look better then the VOLK.. but the VOLKS are forged
Thanks ~ Steveo
Old Mar 10, 2007 | 05:51 AM
markdaddio's Avatar
As far as 18x10 on the rear goes. If you are running at a lowered ride height where the wheel can get to the fender lip, it won't work. If you are going to keep ride height close to stock with some stiffer springs then it might, but I don't see what the advantage to doing that is.
Old Mar 10, 2007 | 05:56 AM
evo150's Avatar
Mark
you can run the 5zigen fn01rc 18x9.5+35 front and back no spacers
Old Mar 10, 2007 | 06:02 AM
Sharkbite2000's Avatar
19x9.5 , I had to roll the fenders on all 4 corners.
