brembo pads
what do you recommend I do?
Search for a set of Hawk HPS pads. Front and rear you should be able to them for around 150-200 depending on where you get them from. They are much better than stock and less brake dust.
If all you're going to do is drag, pick up a cheap set of Hawk HPS pads and your good to go. It'll match your needs perfectly, you dont need that oem crap. All you do is drag race, you can use anything cheap man.
Just make sure your car stops at the end of the run
Arbi
Ferrodo pads work great, I got a great deal from www.z1auto.com
Here are the best prices that I've found for pads:
OEM
$200/fronts & $200/rears = $400/set w/o shipping
https://www.evolutionm.net/forums/sh...d.php?t=231811
Ferodo DS2500
$275/set - combo price shipped
https://www.evolutionm.net/forums/sh...d.php?t=260509
Side note on Ferodos: Be sure you re-use the fabric-like shims that are glued onto the backs of your old OEM pads.
Hawk HPS
$115/fronts & $71/rears = $186/set
https://www.evolutionm.net/forums/sh...d.php?t=228071
PM vendor for the special EvoM price
You can't go wrong with any one of these. Good luck.
OEM
Ferodo DS2500
Hawk HPS
OEM
Ferodo DS2500
Hawk HPS
OEM
Ferodo DS2500
Hawk HPS
OneCrzyEvo21
May 24, 2016 10:34 AM
