Any one with Volk/Espelir question????
More INFO on Espelir ASD
The test was performe not too long ago. Obiously we are going to measure again after month. The drop on spring should be around 35mm - 25mm. And yes, they are not really low spring. This spring will be performance spring where the spring rate will be stiffer than factory springs.. AGAIN, we will get more info for you guys
Do you guys have pictures
I was wondering if you have some pictures of the te-37 and the graham lights wheels for the evo in 18". And on the TE-37s can you get them in silver or graphite type color. On the site I thought there was only white and bronze. White is hard to keep clean and bronze is hard to match the color of your car unless you have black or white. Also why don't the te-37's have a center cap that comes with the wheel at those prices it should at least have a center cap.
Confused with which spring you guys are running. Espelir listing for the EVO says the spring is the Active GT spring not the Active Super Down spring. Active GT spring rates are F 40K R 43K ??? How about the Super Down Spring.
Value
We are working on part number at this time.. You can pre-order them through our distributors. Just let them know the description.. I will post the part number as soon as it's available..
It should be EAS0?? Thanks
