car pulls to the right....... still
Old May 14, 2007 | 03:25 PM
1320 Engineering's Avatar
so i took my car back to the dealer for the "5000 mile service" as stated in the manual... they rotated my tires and the car pulled to the right the whole way home... i could change lanes without touching the steering wheel. I figured an alignment would fix the problem so i took my car to the firestone shop down the street and got an alignment. the mechanic there told me that he got the car aligned as good as it will get according to the mitsu spec. but the car still pulls to the right......... any suggestions?
Old May 14, 2007 | 03:26 PM
Defcon5Es's Avatar
probably ur rims is the problem...
Old May 14, 2007 | 03:28 PM
i have stockers
Old May 14, 2007 | 03:31 PM
ak47po's Avatar
Take it to the dealer.
Scawt's Avatar
Take the car back and make them print out the alignment specs. Post it up here.
Old May 14, 2007 | 03:33 PM
they showed me the alignment specs everything was in the green in the printout so i guess it was alright... i didnt take them with me though ...guess that was dumb
Old May 14, 2007 | 06:07 PM
jimsevo8's Avatar
If the pull happened right after they rotated the tires you might have a broken belt in one of the tires. This will also cause a pull. Have them switch the tires back, or switch the 2 front tires from side to side yourself and see if the pull moves to the other side, or goes away. If it does, then there is a broken belt in one of the tires.
Old May 14, 2007 | 07:02 PM
is there any way to fix a broken belt or do i have to get new tires?
Old May 15, 2007 | 08:13 AM
19psi's Avatar
hmm...I am sort of having the same prob.
Let me know when you get it fixed.
Old Jun 8, 2007 | 05:18 PM
JDMCT9MR's Avatar
I had a similar problem.I took my car to a local suspension shop that deals with a lot of track cars.The wheel alignment was straight and the corner balancing was almost perfect.They ended up switching the 2 front tires and flipped the tires to go in the correct direction.I also had to have my steering wheel centered.They told me that they have heard that sometimes when the tires heat up at freeway or higher speeds and expand,sometimes a tire may not shrink back down to stock specs and that may cause the car to pull to the left or right due to one tire being somewhat larger in overall size.
Old Jun 8, 2007 | 06:37 PM
jimsevo8's Avatar
Yes, I forgot about this. The Advans are directional and can do some funny things when mounted in the wrong direction. Usually they just make more noise, but you might want to check that. There's an arrow on the sidewall of the tire that shows the direction of rotation. Make sure that's pointing the right way.
If it is a separated belt, the only repair is to buy a new tire.
samterry1234
18
Dec 30, 2011 08:49 PM
IXToes
Feb 27, 2010 09:32 AM
WillH19
Lancer Troubleshooting
Dec 12, 2007 06:00 PM
swordfish
Feb 21, 2007 08:15 PM
lancerslc
Jun 14, 2003 04:07 AM
