Tire Pressure
Tire Pressure
I recently read;
http://www.chris-longhurst.com/carbi...yre_bible.html
And they have a section on tire pressure about factory labeled vs tire rated. I was wondering if anyone has experiences with using the 10% max rule with the tire recommendation vs. the factory with aftermarket tires.
Thanks!
Thanks!
i normally run about 3 to 5 psi more than the recommended tire pressure, depending on car. I have run as high as 44 psi on one of my trucks but when running though a puddle at the gas station i noticed that at that pressure the tire didn't have complete contact with the road and dropped the pressure back a bit. I also recommend to run atleast 2 more psi for every inch larger wheel than factory.
i try to keep the difference between the fronts and rear as recommend by manufacture but i usually run 2 psi more in front and 3psi more in rear unless during auto cross then i run 41front 38psi rear
