I fixed the pull to the right prob.
This kinda makes me look stupid but I am gonna post this up anyways.
I've had my zeals for about a month now and it has always pulled slightly to the right after the install.
I've checked and double checked the height settings and they always turned out to be correct on all four corners.
I probably took the car to 3 different align shops and they said the alignment is very good and cannot do a better job.
So, one night I decided to check the spring preload settings.
The rear measurements were dead-on.
But...sure enough, the front's were off by quiet a bit. My driver's side preload
was way off.
Adjusting the preload so the both sides were equal immidiately fixed the prob.
Yeah, I know I know it was stupid of me not to measure the spring preload of the front's. I just forgot to double check the fronts.
So the lesson has been learned.
For those of you that has coilovers and your car is pulling to either direction, make sure you double check your preload settings.
was way off.
