Alignment seeting for daily driver needed
Sorry, I just need quick settings for everyday driving and once a month autocross.
I was told -1.5 camber upfront.
What about toe in or out? Also what about the rear?
I am going to the alignment shop in the morning.
Thanks guys,
Thanks guys,
i would really try and search this one out. alot of mixed feelings on this subject, well kinda.
i would set toe to zero and -1* in the rear for a daily driver. if you got a little harder of a tire maybe -1.5* in the rear. its really up to you and what your tire buget for the year is like???
okay I got tanabe springs and my passanger side front tire on the inside is bolled I got a wheel alignment done after I put the springs but I didn't get my tires balanced and I just purchased a cambr kit from corsportusa.com and I am buying all new tires so what are ur suggestions on what I should do regards to camber in the front and rear I am not rich to be buying tires every 10K so I would like something that doesn't reqire me buying tires on a regular .....thanks ppl...give me ur suggestions
These are the factory Mitsubishi alignment setting
Front: Camber -1 +/-30' (out of factory)
(optional camber -2 +/-30 by flip camber bolt)
Caster 3 degree 55' +/-30'
Toe in 0 +/-2
Rear: Camber Same as front
Toe in 3 +/-2
Thrust angle 0 +/-09'
all these specs are from Lancer Evo Magazine in Japan, VOL. 28
Toe in 0 +/-2
Toe in 3 +/-2
