Caliper rebuild/cleaning
Old May 25, 2007 | 12:31 PM
stylin_g's Avatar
Hey Guys, I searched around here and didn't come up with anything... Anyways I wanted to know if there is a kit out there or not to rebuild or clean the brembos.. as mines are in need of cleaning.. and since they need cleaning I thought might as well rebuild it to perform at its best.. so if anyone can help that be great
Old May 25, 2007 | 12:56 PM
evo150's Avatar
i wouldnt rebuild the calipers unless there is a specific problem(cracked seals etc.). if you are just wanting to clean your calipers to look new again, and you dont have any chipping clear coat, i suggest a light sanding, then a couple coats of hi-temp clear. check out the how to forum for a complete write up. its a little harder to do if the clear coat on the calipers is chipping off because you have to scrape off all the old clear coat.
ReivaXVrai2
19
Jan 4, 2015 10:57 AM
EvoDan2004
Dec 30, 2012 12:14 AM
phizzalot
19
Dec 23, 2011 10:57 AM
doridori
Jan 4, 2006 05:34 AM
