Anti Lock Light
Old Jun 3, 2007 | 03:48 PM
Melancholy's Avatar
Anti Lock Light
Hi I just bought my 03 Evo about 2 months ago. When I am driving 70 MPH and below my car runs fine, but when I go above 70 MPH for about a minute or less my Anti Lock light comes on. When I stop and turn the car off then back on the light always turns off. This happens every time I go above 70 for some reason. Just wondering if anyone had an answer for this or a reason?
Thanks you.
Old Jun 3, 2007 | 05:56 PM
jimsevo8's Avatar
It depends on what the fault code is. If it's a fault for a wheel speed sensor, then I might suspect......yes....a bad wheel speed sensor.or maybe there is a problem with the wheel bearing or CV joint. When you go over 70 it might start to wobble and take the toothed ring on the CV joint out of range of the ABS sensor.
