need pic of ix se with s.techs
If you can spend $30k atleast do some research and buy some springs that actually benefit the car like swift or espelir instead of being ganster and wanting to drag your bumper everywhere
The fact that you call them "lowering springs" is just awful, and the fact you consider adding springs make the car aggressive is awful, too. Look, you don't lower the car for looks - you lower the car to improve performance. If all you do is a set of springs, you are not going to improve performance. You are just going to mess up the intricacies of the stock supension, and it will not BE aggressive - it will just PRETEND to look aggressive.
+1
I went the "lowering springs" route on a previous car and the lowering aspect was the only thing it did. It's not a performance mod IMHO if you're going to use smaller springs on OEM dampers. They aren't designed to be compressed 1"-2" without being under load. Save up and do coilovers. I just installed some KW3's and it's a whole new world compared to lowering springs and/or the stock suspension.
+1
check on Speed Element.. That's where I got mine. Don't do S-tech's, save the money and do your car a favor, get Either a good coil over or Swift, espelir, tanabe. Youle thank us later.
