ultimate suspension setup? ANYBODY?
Old Jun 29, 2007 | 08:00 PM
Erik@MIL.SPEC's Avatar
You may as just well get the Motons earlier than later, meaning, if you have done enough track time on the stock suspension you may as well spend $4700 on the Motons straight-up, instead of spending $1000-$2000 on a set of good (but lesser) coilovers and then eventually Motons...but that's just me
Old Jun 29, 2007 | 09:49 PM
Balrok's Avatar
Robi's KW club's. They beat out the moton's with a professional consistent driver last time attack. And even before that i believe. Also they are cheaper and he can customize them for who you and and what you do with the evo. Plus he'll come to you...hows that for service.
Old Jun 29, 2007 | 10:07 PM
That is very good information. Congrats to Robi. I have not decided on what set-up I may go with in the future. My point was more of a general one in the sense that I would rather go from A to C then A to B to C. It is cheaper in the end
Old Jun 30, 2007 | 06:53 PM
2muchboost's Avatar
wow. I did not know they were that good and cost less than the motons. good to know.
and that's damn good service!
Old Jul 2, 2007 | 04:12 AM
WarmPepsi's Avatar
if money is no object, robi will sell you something better than his clubsports, or comp 2's.
Not sure what the relationship is, but if i remember right, he's running dms 50's on his car. Again, if money was no object.
It's more getting someone to set it up, and believing in their experience and their way of doing it. a 5k suspension isn't better than a 200 set of springs, if it wasn't properly done as a package.
edit: i can't complain a bit about my clubsports.
Old Jul 2, 2007 | 07:05 AM
XK120's Avatar
Custom Moton 4-ways
Old Jul 10, 2007 | 12:02 PM
GTWORX.com's Avatar
Just thought i'd post some pretty pictures of a recent customer's custom Moton Clubsports we put together....
Sorry, I can't give exact details on his set-up. But we're using Eibach springs, Works Camber Plates, and Works rear pillowball mounts. And sorry for the crappy pics. And I reversed the helper springs after these pics were taken.
The Motons are simply a joy to work with. Everything fits together so perfectly, everything goes where it's supposed to, and the tolerances are just perfect. Even the way they are packaged impresses you. The quality is just amazing, to say nothing of the on track performance. Everything just works perfectly. It makes you happy that somewhere....someone out there is doing it right.
sigh.
- Andrew
Old Jul 11, 2007 | 07:43 PM
xX v0oDo0 Xx's Avatar
sigh.
- Andrew
Geezus, that's gorgeous Andrew...Makes my Works Ohlins Stage III DFVs look like Megans, hahaha...Can you post pictures once installed, if it is okay with the customer?...
Old Jul 11, 2007 | 08:17 PM
kduncan01's Avatar
Check with Robert Fuller, As Warmpepsi put it setup is VERY important. He can supply a custom valved set of dampers and setup the car for you - it really is the best way.
PM me if you want his number
Old Jul 12, 2007 | 07:33 AM
DaWorstPlaya's Avatar
Quoted for truth! Setup is very important ... when you head into the territory of race quality shocks all the big names, Koni (not their cheap stuff), Motons, Ohlins, DMS, Penske are very good. The construction, design and valving is superiour to all the cheapo stuff in the market. Pick your poison ...
Old Jul 12, 2007 | 07:43 AM
dadriva's Avatar
I'm VERY happy with my Robispec'd KW Clubsports.
Robert came to me, installed them C/O's, laser alighned, and corner weighted the car in one day. I was on Tein Flexes prior to being Robispec'd and the difference is / was truly night and day.
Old Jul 12, 2007 | 07:52 AM
WarmPepsi's Avatar
hey, i can't always be wrong.
edit: i'm jealous, i want some pink springs. i'll see if robi can hook it up
Old Jul 12, 2007 | 08:54 AM
GTWORX.com's Avatar
I'll see what I can do.
- Andrew
Old Jul 13, 2007 | 09:36 AM
Ludikraut's Avatar
To the OP: my $.02 ... save the money, stay on the stock suspension (fix some of the basic suspension geometry issues), and then spend your money on learning to push the limits of your current setup ... as in professional instruction. Once you can say that you have mastered your current setup, then it's time to think about upgrading ...
l8r)
Old Jul 13, 2007 | 10:05 AM
mexicanevo's Avatar
Just installed my KW v3's in my ride!! Need to dial them in now.
