rotor question
Old Jul 20, 2007 | 06:37 AM
EVOL2003's Avatar
rotor question
is it ok to get the stock brembo rotors "turned" or do they have to be a certain depth because of the size and performance of the brembos?
edit i meant rotors
Old Jul 20, 2007 | 06:40 AM
Greg K's Avatar
you don't turn pads you can have the rotors turned, but I'd recommend against it as it just makes them warp faster b/c of the reduction of mass.
Old Jul 20, 2007 | 11:24 AM
Erik@MIL.SPEC's Avatar
Just upgrade to StopTech/Centric rotors.
It's only like $230 for a pair of slotted fronts.
Old Jul 20, 2007 | 02:35 PM
grillpt's Avatar
You can turn you rotors if you want. Look for the mininum width on the hub of the rotor, its stamped in, you'll need a mic to check them.
I'm not sure I suggest it, but you can do it.
Old Jul 20, 2007 | 04:07 PM
teamnemesis3's Avatar
I heard your ONLY suppose to resurface ur ROTORS ONLY if u need too... so example if u notice ur streering wheel shakes when braking on the highway then resurfacing ur rotors will probally help stop the shaking... if ur rotors look and feel right I would also suggest not it doing because it only makes them "weaker, thinnier , etc."
Old Jul 20, 2007 | 06:19 PM
EVOL2003's Avatar
the rears have a small line in um....from the first set of pads....pads r fairly new rotors r original thanks guys
