Brake Combo - Street Performance
People, ,need some advise from you guys....I'm pllanning to add a break combo to my EVO IX...Don't know what to do...what do you suggest?
Slotted vs Xdrill
BRake pads
Stainless braidded breakk lines
oil
What manufacturer is the best and from whoo to buy?
Need your advice. thanks in advance.
Slotted vs Xdrill
BRake pads
oil
Upgrade your pads when you need to. Tons of threads on which to pick.
i auto-x and street drive.... my setup seems to work just fine for both
centrix cross-drilled and slotted rotors
hawk hps carbon brake pads
russells stainless steel brake lines (f and r)
DOT 4 fluid
dont have any brake issues at any time, whether in at the track or in the canyons
DOT 4 fluid
This setup is what I know a couple people run and have good success.
Rotors: RacingBrake slotted rotors (2pc in front if you have the $$$$...but not really needed unless hardcore road racing)
Pads: Ferodo DS-2500, good all around pads
Goodridge stainless lines
Motul fluid
Also brake air guides or some type of improved ducting does wonders. Some say to remove the splash shield but I have yet to experience doing that....yet
Motul fluid
