Just changed my pads
Old Aug 11, 2007 | 06:54 PM
05WhiteEVO8's Avatar
So I just changed out my pads and everything went easily together except for the anti-squeal shim, I cannot get them to stay in place, they are in pretty good, then I go for a test drive and they fall out. They are rattling the whole time as well. I have removed them completely for the time being just to ensure they are the only thing making niose and they are. Anyone have a suggestion on how to get these to stay on more securely, or do I even need them on. Thanks
Old Aug 11, 2007 | 06:57 PM
idriveanevo's Avatar
they should be held in by the pins, at least mine are...
Old Aug 11, 2007 | 07:16 PM
They are when I first set them up, then they loosen out and start rattling. This happens within a few seconds.
Old Aug 12, 2007 | 02:40 PM
spdracerut's Avatar
Did you use any high temp anti-seize compound on the shims? Permatex makes some....
Old Aug 13, 2007 | 05:52 PM
No I didnt put them on these, would that stop them from rattling and being generally loose?
Old Aug 14, 2007 | 01:11 AM
spdracerut's Avatar
It should.... it's actually in the factory service manual to do so. In case you didn't notice when you pulled the shims off the stock pads, there was gunk on them between the shim and pad
Here's some stuff, I think I used the hi-temp silicone formula:
http://www.permatex.com/products/aut...nce_repair.htm
I think some guys like to use this though:
http://www.permatex.com/products/aut...sket_Maker.htm
Regardless, there's some good write-ups on here and socalevo for doing a pad swap.
Old Aug 14, 2007 | 01:22 AM
tripperfx3's Avatar
I actually dont have the shims (Friend did the install for me cause i was busy with work and he threw them out ) and i dont have any noise or rattling. It should help from what your describing though.
Old Aug 14, 2007 | 02:02 PM
I am not talking about the shims on the pads, the new pads I have have some on them. I am talking to the little metal piece that goes on the outside once the pads are on the caliper, between the two metal clips that go through the pads themselves.
Old Aug 14, 2007 | 02:57 PM
evodrivesme's Avatar
well i changed mine and they all installed fine but for some reason my front right sweellllzzzz bad i dont know why i did nothing different and none of the others do it.
Old Aug 14, 2007 | 03:08 PM
mievoIX's Avatar
Edit: Just figured what you're talking about. That is a sping type retainer. If you are looking at it with the ends towards the floor what you need to do is flip it the other way and install it that way. You will see that the ends are designed to hook on to the pins.
You're gonna have to pull one pin 3/4 of the way out, your choice which one. Then, latch one end of the retainer to the pin that is fully installed, next while pushing on the other end of the retainer tap the pin in.
Old Aug 14, 2007 | 05:22 PM
Hmmm, I think I understand now. I will try it this weekend. Thanks for the clarification. I don't need any anti seize on these do I? Thanks for the help guys.
Old Aug 14, 2007 | 11:02 PM
evo150's Avatar
here is a good pic for you
Old Aug 15, 2007 | 04:02 AM
mievoIX's Avatar
Good pic, exactly what i was trying to explain. You need to lube the pins so that the pads can slide freely and to prevent rust from forming and you could coat the retainer with some too to prevent rust.
