Car slips
Car slips
Hi, I wonder what is causing my car to slip, it happens often when i go on a bridge, but the one that have like asphalt on it, not concrete,
I have my 2" springs, new tires, Hankook S-R2, I had my car balance all four wheels and also the alignment.
is very little, you can barely feel it in the passenger seat, but if your driven the you feel like the tail of the car slips just a little bit, its kinda scary, cause you think your going the hit the car next to you..
well, hope to get some ideas
What tire pressures? With a single driver your rear tires should have 3psi less than your front. If you have them all the same it sort of feels like the back end wants to pass the front end.
but in the other hand when a drive in a street that is asphalt the car just runs good.
the things is on this bridges, I was thinking the alingment, I would have to take it again to the shop, but its kind of weird, because if its alignment it will always behave like this, and it dosent happend like that
If the surface looks at all like this it's normal, I've seen surfaces like this with asphalt filling in the voids also. The feeling I get is kind of a wiggle and not just in the back.
