help wheel spacers
ok i have the ro_ja wheels and im using a 3/16 spacer and its still not enough to clear the breaks so i was thinking i need to get a 1/4 spacer maybe? but will i need to get longer studs to fit the spacer?
thanks for the help guys
We usually refer to spacers in terms of millimeters. Using the standard conversion of 2.54cm = 1 inch, that would tell me your 3/16" spacer is 4.76mm, and a 1/4" spacer would only be 6.35mm. That's a VERY small change in spacer size, so are you sure that will be enough to clear? That may not require longer studs, but it depends on your wheels and lugs. If you go as far as 10mm spacers, which is about 3/8", then you'll probably needs longer studs for sure. However, you'd have to tell US based off how everything fits.
