quick question about installing brake pads
Old Aug 30, 2007 | 10:44 PM
letMeIn's Avatar
Hi, while changing stock brake pads I noticed there is a spacer between stock pad and metal shim. Im installing Ferodo 2500 pads right now but they don't come with any spacers. Should I reuse the once from stock pads, or just put the anti-seize compound between the brake pad and the shim.
I have a track day on saturday, and have to finish my brakes tomorrow. Already did 3 of them before I noticed that spacer on stock pads. Will I be OK if I don't reuse those "copper" spacers ???
here are few crappy cellphone pics
thx
Old Aug 31, 2007 | 05:24 AM
Kronik's Avatar
it will be ok but probably make a lot more noise without them.
Old Aug 31, 2007 | 06:25 AM
WheelGap's Avatar
+1
Use those shims or your pads will squeal like a stuck pig. I had DS2500's put on and they didn't peel those shims off the OEM brake pads, and my brakes were intolerably loud.
Old Aug 31, 2007 | 07:13 AM
Lazeum's Avatar
I've got DS2500 too.
I used anti seize compound + stock shims. No noise at all with the brakes
Old Aug 31, 2007 | 07:15 AM
Greg K's Avatar
use the stock shims and copper permatex antisieze.
Old Aug 31, 2007 | 08:36 AM
thiouk's Avatar
I switched to Hawk hps pads and I took the metal spacers out, everything works fine. A lot of noise , but at the track who really cares.
Old Sep 1, 2007 | 12:58 AM
letMeIn's Avatar
thats what I was thinking.. Well its almost 4am, leaving in a few min for Pocono Raceway.. Will let you guys know how the brakes felt without the copper shims.
thx guys
