inside of tires worn(camber)?
Old Sep 27, 2007 | 02:40 PM
Mitsu3's Avatar
I noticed that the inside of my tires are worn more than the outside at 7000miles. Is it because of the stock camber or is mine out of wack. Also the front tires should wear faster than the rears right?
Old Sep 27, 2007 | 03:06 PM
BenJ's Avatar
That is normal with the Evo's and yes it is due to the stock camber settings. Feel good if you get more than 12k out of your tires.
Old Sep 27, 2007 | 03:11 PM
HiVoltEVO8's Avatar
It is actually toe
It is actually toe in or out that wears tires quickly. get an alignment with 0 degrees toe and you can get 15-17K out of stock tires
Old Sep 27, 2007 | 03:13 PM
RedAustinIX's Avatar
Yep - I just bought new fronts at 12k miles... Same thing, almost bald on the insides. I had the wheels aligned when I had my new tires mounted, but don't remember the settings.
RedAustinIX
Old Sep 27, 2007 | 03:18 PM
Cali2MDevo8's Avatar
Registered User
Toe this, Toe that............usually toe is set at 0. Severe negative camber eats the inside of tires
jason
Old Sep 27, 2007 | 03:30 PM
nyaegermeister's Avatar
yep, after i lowered my dsm i had a few years ago the camber was off and ate the inside of my tires off in no time.
Old Sep 27, 2007 | 03:40 PM
RAZOREXPRESS's Avatar
i replaced my tires at 10k stock tires are great but,they dont last long
