allignment settings your opinion?
Old Sep 28, 2007 | 09:10 AM
Jeffs2006EVOIX's Avatar
just got my MR's allignment done after getting some new shoes put on. Any people that know allignments this is how my car was dialed in, this is on a bare stock 06 MR.
LF..-1.2 camber, RF..-0.9 camber
LF..3.8 caster, RF..3.8 caster
LF..0.0 toe, RF...0.01 toe
front total toe...0.0
steer ahead...0.01
LR..-1.0 camber, RR..-1.0 camber
LR...0.10 toe, RR..0.14 toe
rear total toe..0.24
rear thrust angle..-0.02
so how does this look? was done on a digital hunter rack.
Old Sep 28, 2007 | 09:36 AM
19psi's Avatar
looks good for a daily driver.
Old Sep 28, 2007 | 09:44 AM
cfdfireman1's Avatar
More camber up front and make them the same, arrow out on the bolts. Get rid of the toe in the rear.
Aim for rear camber X 2 = front camber
Old Sep 29, 2007 | 03:37 PM
wrcwannabe's Avatar
Yep zero toe all around, fronts need to be -2 camber. Is the front camber bolt flipped over? Generally get about -2 -2.5 from that.
Rear camber for street work about -1
The car will turn in and rotate much better when set this way.
Milburn
Old Sep 29, 2007 | 03:49 PM
Warrtalon's Avatar
0 toe all around and make the front camber even. Go to -2.0 up front if you want it to be aggressive but not too bad on the tires, or just leave it around -1.0.
Old Sep 30, 2007 | 10:11 AM
Solo II Evo's Avatar
I'm a weekend autocrosser (car is not DD anymore) but here are my specs:
-1.6/-1.9 (Maxed out)
3.?/3.? caster
FR Toe -.012
FL Tol -.012 (1/8th inch total toe out)
0 toe rear.
Old Sep 30, 2007 | 10:37 AM
Huy's Evo's Avatar
fix your toe in the rear to 0.00 it will make your car drive straight and fix your camber because it look like it is pull right.
