Another brake clearance question
Old Oct 3, 2007 | 12:59 PM
Chiba_kun's Avatar
Will 17x8 wheels w/ +40 offset clear Brembo's?
TIA
Old Oct 3, 2007 | 06:57 PM
Chiba_kun's Avatar
Bump...anyone?
Old Oct 4, 2007 | 07:16 AM
Chiba_kun's Avatar
Ok, so I searched until I found that the factory wheel size is 17x8 w/+35 offset.
The wheels that I found, as previously mentioned, are 17x8 w/+40 offset. So does that mean I'll need 5mm wheel spacers or does that mean I'll have an extra 5mm of clearance???
Old Oct 4, 2007 | 11:01 AM
Vostok 7's Avatar
The lower the number the more the rim edge sticks out from the hub face. So a +40 vs. a +38 (which is stock on the IX) will have a rim edge 2mm closer to the hub face. So you could use a 5mm spacer but you're really better off finding a wheel with a +38 - +30 offset.
- Patrick
