megan coilover help !!!
hi guys
i'm haveing that clucking/rattle comeing out of my rear end (both side ) it have only been on for two weeks ..
i did my seach i know alot people solved the problem by tighting up the 17mm nut under the adjustment knob ,, i did it , didn't fix it ..
is there anything else i can try or to check for
please help out !!!
please help out !!!
i did they say it sound like it's comeing out of the shocks ...
but i'm not sure wat should i do now
check the bottom adjustment nut. it should be tight. check it with the spanner wrench. sometimes it may seem tight, then you apply the spanner wrench and can tighten it up another half a turn. once it is tight, take a deadblow hammer and tap the spanner wrench to lock em down.
