STI wheels on the Evo??
I already tried. Would not clear the calipers. That's why I ask. I know that I need spacers to make it work. But I just want to know how thick and will the wheels sticking beyond the fender.
You too are an idiot. You would need a minimum of 15 mm spacers and extended studs, like i said before.
yes we have a smaller offset which means that where the wheel mounts is closer to the center of the wheel. so if there is a bigger offset wheel u have to run, u need to space your hub out further so they will clear. then only thing about this that is somewhat a problem is that when u space your wheel out further, u put more stress on the lugs and the hub. 15mm is also almost 5/8ths of an inch so that is a pretty good amount
