Camber?????
Old Jul 15, 2003 | 02:50 PM
zyounker's Avatar
Camber?????
Ok, i went to get my car aligned and they told me they could only get -.4 in the front.. And i heard of people running up to -2... So What is the trick????? do you just use the stut assembly to adjust at the 2 bolts below the spring???? Cause that is how he was doing it.. And i have never aligned a car..
Here are the settings i am thinking of running.
-2 Front
-.5 Rear
1mm toe-in front
0 toe rear
I was thinking of maybe going down to a -1.5 in front rather then a full 2*..
Opinions and help?? Yes i know it will eat my tires
Thanks,
-Zach
Old Jul 15, 2003 | 02:57 PM
2Cool's Avatar
Problem with the front camber is that the Evo comes with a flat sided eccentric bolt, which has only two possible settings. Supposed to be -1 and -2 degrees, but really ends up being ~-.75 and ~-1.5 or so. Any more will require mods or camber plates.
The rest of your alignment looks good though.
Old Jul 15, 2003 | 03:03 PM
zyounker's Avatar
Thanks.. Here is the link on setting front camber you gave me in the other thread.. good info case anyone searchs and comes accross this.
https://www.evolutionm.net/forums/sh...threadid=22331
Old Jul 15, 2003 | 03:54 PM
EVO Rosso's Avatar
Here were my results: https://www.evolutionm.net/forums/sh...threadid=28038
You need 0 toe both front and back.
The bottom line is the the camber bolt setting in the front is a crap shoot. I think my results were better than most as far as getting so close to -2.0. The rear is tricky because the toe changes as the camber change so it takes a while to get it right.
Good luck and you will really enjoy it with more camber up front.
EDIT: Jump on http://www.mitsubi****echinfo.com/ before they start charging and print out pages 33A-7, 33A-8, 34-6 and 34-7. Then take that with you to the shop.
Old Jul 16, 2003 | 10:05 AM
zyounker's Avatar
Ok, redid the alignment today.. kinda hard to get the negative camber up front.. I could hit ~2.1 before tightening the bolts down..
But after tight got -1.6 drivers side -1.7 passanger side.
0 toe all around and -.6 and -.7 rear camber.. would have like less on the rear but he was done with that when i showed up.. and i helped with the front to get it right.. You really need someone pushing in on the tire/hub when you tighten the bolts back down.
-Zach
Old Jul 16, 2003 | 12:06 PM
wojo's Avatar
Originally posted by zyounker
Ok, redid the alignment today.. kinda hard to get the negative camber up front.. I could hit ~2.1 before tightening the bolts down.. -Zach
That's excalty what happened to me.
After tightening the bolt I was only able to get -1.5 (with the driver) on both sides. 0 toe all around.
