New Whiteline Catalog
Looks like Whiteline is coming out with some more stuff for us. Andrew you have any news for us? hehe
Lancer EVO VII-VIII-IX 01-06
F p Bush kit-control arm front W0593 2 High performance
F p Roll centre adjust kit suit LHD & RHD KCA395 2 reduces roll. Essential for lowered cars
F p Steering precision kit JDM RHD only KCA387 2
F p Steering precision kit USDM and LHD KCA390 2
F p Strut top-camber/caster adj MOTORSPORT-RACE. KCA252M 2 suit small diameter coil-over race springs ONLY
F ˜ Spring-coil lowering kit-Control. 73240 2
F Ó Swaybar link kit-spherical rod end KLC39 2 adj extra h/duty replaces OE ball-joint type
F Ó Swaybar-heavy duty BMF48 R 2 26mm
R p Brace-strut tower alloy adj KSB628Q 2 with Quick Release clamp
R p Bump steer correction kit KCA388 2
R p Bush kit-control arm frnt uppr innr W0590 2 High performance
R p Bush kit-control arm lwr shck mnt W0589 2 High performance
R p Bush kit-control arm rr uppr innr W0591 2 High performance
R p Bush kit-diff mount excl EVO IX W0592 2
R p Bush kit-toe control arm inner W0588 2 High performance
R p Bush kit-trailing arm front lwr W0594 2 High performance
R ˜ Spring-coil lowering kit-Control. 73241 2
R Ó Swaybar link kit-spherical rod end KLC002 2 adj extra h/duty
R Ó Swaybar-h/duty Blade adjustable BMR65Z R 2 22mm
R Ó Swaybar-heavy duty BMR65 R 2 22mm
R Ó Swaybar-X h/duty Blade adjustable BMR65XZ R 2 24mm
The one there lacking, is the Front Control Arm, the one in the back. Perrin just came out with an all metal one, with adjustments, but at a $2XX price tag. I'm more interested in a Poly. non-adjustable one as a replacment.
Drew, the only thing that worried me was in the notes for the camber kits was "small diameter race springs only". Wouldnt be able to use those for regular lowering springs, but be great for the coilover guys, specially combined with some KW's {thumbsup}
Looks like another possibilty on lowering springs as well...
Keep us in the loop, we love the whiteline stuffs!
No info yet, thats why we are speculating on them. Basically new catalog just came out but we havent seen the goods yet. Figure Andrew and Cal will fill us in as it comes available.
Their Subaru plates use a huge pillowball that's much bigger then Cusco's. This is good for longevity and keeps them nice and quiet. Not harsh at all either. Also, there's very little raising of the car. At full negative they're almost completely non-raising. Oh and they add a good amount of caster.
From what I've heard, the EVO versions are gonna be pretty similar. Sweet.
- Andrew
- Andrew
